Previous Topic: Edit PropertiesNext Topic: History
Delete a Tree Node
You can delete a selected node or group of nodes in the Explorer tree view by clicking either the File, Delete command or the Delete toolbar button.
The Confirm Delete dialog appears. Click Yes if you are sure you want to delete the selected node. Click No to cancel the deletion.
Note: Depending on the plug-in, this operation may be restricted. Also, this dialog does not appear if you cleared the Confirm on Delete check box in the Explorer GUI Options dialog.
