Previous Topic: Explorer BarNext Topic: View Properties
Tree View
Tree View is the default view, and it provides the main navigation to the various features of the Explorer GUI and its installed plug-ins. The tree view displays the following types of nodes, depending on the installed plug-in that is currently in focus:
Root
The first node in a tree. More than one tree can appear in the left pane.
Parent
Nodes that have child nodes. Parent nodes appear in the left and right panes.
Child
Nodes that have a parent node. Child nodes appear in the left and right panes.
Leaf
Nodes that lack child nodes. Leaf nodes are usually displayed only in the right pane.
The plug-ins in some cases use the concepts folder and object. A node can represent a folder or an object. Plug-in help describes the exact terminology used for a plug-in. A plug-in can use more than one tree and, therefore, have more than one root node.
Folder
By definition, folders are always root, parent, or child nodes but never leaf nodes.
Object
Objects may be root, parent, child, or leaf nodes. Rules do not apply strictly here. In some plug-ins a node is an object, not a folder, containing child nodes.
