In some cases, you may want to use an implicitly trusted domain when creating security profiles that is, a domain that is not in the directly calculated list. To enable this type of domain, the Security Profiles dialog lets you add and remove authorities, but only within the Windows NT name-space (winnt).
To add an implicitly trusted domain
The Security Profiles dialog appears.
Note: You must have the access rights to open this dialog; otherwise, a security error message is displayed. Administrators (on Windows) and root (on UNIX) have these access rights by default.
The Add Security Profiles dialog appears.
The Add Implicitly Trusted Authority dialog appears.
The specified domain is added to the list of available authorities.
Note: Adding a domain to the authorities list does not confer trust to that domain; this is enforced by the operating system. You cannot add a domain to this list and have the manager trust this domain unless the underlying operating system already trusts the domain in question.
