Software delivery lets you shut down a target computer after completion of the last software delivery job. SD provides the shutdown-related job and calendar options. A combination of the job and calendar options controls the shutdown behavior of the target computer. You can use these options to decide when to shut down a computer, whether to shut it down or not, or how to define non-conflicting time ranges within which it is appropriate to shut down. This functionality helps ensure that the target computers use power in an optimal manner and support the defined Green IT policies of the organization.
