To shut down the computer after completion of the last SD job, configure the Shutdown Behavior policy. You can specify a value for this policy while creating a configuration policy. Once the configuration policy is created, you can seal the policy and apply it to the target computer like any other configuration policy.
To configure the Shutdown Behavior policy
A list of all the shutdown policies appears.
The Setting Properties dialog opens.
Specifies that the computer must not be shut down after completion of the last SD job. This is the default value for this configuration policy.
Shuts down the computer if the Boot Level after execution property is set to the Shutdown machine after last job option. The parameter ignores the power management calendar setting in this case.
Shuts down the computer based on the power management calendar settings of the target computer. The parameter ignores the Boot Level after execution property if the property is set to the shutdown option.
Shuts down the computer based on the Boot Level after execution property or the calendar option. It uses either of the two options to decide whether to shut down the computer. It will always shut down the computer if the value of the Boot Level after execution property is set to the Shutdown machine after last job option or the power management calendar indicates that a shutdown must be performed.
Shuts down the computer based on the Boot Level after execution property and the calendar options. It uses both the options to decide whether to shut down the computer. It will shut down the computer only if the Boot Level after execution property is set to the Shutdown machine after last job option and the power management calendar indicates that a shutdown must be performed.
The Shutdown Behavior policy is configured.
