Software Delivery › Tasks › Custom Administrator Message › Change the Security Settings for the Embedded Network Share Path
If you include a network share path in the job container message or the job message, you must change the local security settings for the network share path to work properly.
To change the security settings for the embedded network share path
- Run secpol.msc from the command prompt.
The Local Security Settings window appears.
- Navigate to Security Settings, Local Policies, Security Options.
A list of security settings appears in the right pane.
- Double-click the Network access: Shares that can be accessed anonymously setting.
The Network access: Shares that can be accessed anonymously dialog appears.
- Add the name of the shared folder in the Local Policy setting tab, and click OK.
- Double-click the Network access: Restrict anonymous access to Named pipes or shares.
The Network access: Restrict anonymous access to Named pipes or shares dialog appears.
- Select the Disabled option, and click OK.
The local security settings for the embedded network share path are changed.
More information:
Specify a Custom Administrator Message
