Connection Events Policy Group
The Connection Events policy group controls the types of connection events that are tracked while taking a remote control session. These settings appear on the Advanced tab of the DSM Properties - Remote Control dialog. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Indicates that the viewer has failed to connect and the confirmation is rejected by the host.
Default: True
Indicates an event that is raised when a request for a remote connection from a viewer to a host has failed.
Default: True
