The Remote Control policy group lets you view or edit the existing computer policy properties for remote control management, inheritance, and protection.
This policy group contains the following policy group folders:
Click each policy group folder to view the policies. Each policy object within its policy group folder is derived from a parent object. The settings in the policy object have the option either to specify the setting or to inherit the setting from the parent policy. New policies can inherit from computer policies, global policies, or local policies.
The Remote Control policy group permits the administrator to configure or view the values associated with the policy template that is applied to computers and/or computer groups referencing the policy. To edit a property in the policy list, double-click the property description to display the Setting Properties dialog.
Note: Not all existing policies may be visible within a policy group folder. For information about hiding policies or making them visible, see the Remote Control Administration Guide.
