Previous Topic: smtp Policy GroupNext Topic: Notification Policy Group
Software Contents Download Policy Group
The Software Contents Download policy group lets you view or edit the following policies for software signatures. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Note: Available categories and options may vary depending on the products and components installed.
Contents Download Port
Specifies the port number used to communicate with the CA contents server that holds software signatures. Valid values are 443 (new installations) and 5250 (upgrades).
Default: <locally managed>
Contents Download Server
Specifies the name of the CA contents server that holds the software signatures.
Default: contentupdate.ca.com
Proxy Server
Specifies the name of your proxy server.
Default: empty
Proxy Server Port
Specifies the port used by the proxy server.
Default: 0
Proxy Server User
Identifies the name or ID of the user who has proxy server permissions.
Default: empty
Proxy Server User Password
Specifies the password of the proxy server user.
Default: <encrypted>
