smtp Policy Group
The smtp policy group contains the following Simple Mail Transfer Protocol (SMTP) policies. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Indicates whether SMTP is enabled.
Default: True
Specifies the mail address to be set in the From: mail header.
Default: AssetPolicyViolation
Specifies the host name of the SMTP server.
Default: localhost
