Preference Policy Group
The Preference policy group contains the following policy for security provider preferences. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Specifies the preference order for security provider usage. Altering this value affects the behavior of the system identity and directory integration functionalities of this product. The specified value governs the order in which security is ordinarily negotiated and will change the order in which configured external directories are evaluated for directory integration.
Default: winnt,ldap,unix,nds,x509cert
