x509cert Policy Group
The x509cert policy group contains the following policy for X.509 V3 certification. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Enables the security provider for X.509 V3 authentication certificates, if set to True. If False, disables the security provider for X.509 V3 certificates.
Default: True
