Security Events Policy Group
The Security Events policy group controls the types of security events reported. They appear on the Advanced tab of the DSM Properties - Remote Control dialog. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Indicates that a viewer has connected to a host with a correct user name and password but does not have permission to perform the type of connection requested. This can happen if, for example, the viewer tries to connect in stealth mode without permission or the user of the viewer is not present in the address book containing the host. In this case, the user has no permissions at all. The connection is rejected.
Default: True
Indicates that a viewer has connected to a host with an incorrect user name or password and has been rejected.
Default: True
Indicates that the remote control manager failed to load a configured security provider.
Default: True
Note: For more information about the DSM Properties - Remote Control dialog, see the Remote Control Host Help.
