Software Delivery Policy Group (Common Agent)
The Software Delivery policy group contains the following policies. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Note: Available categories and options may vary depending on the products and components installed.
Defines the types of units supported by the agent plug-in. Valid values are as follows:
Specifies that the supported unit type is the computer itself.
Specifies that the agent plug-in supports both computers and user profiles. A user profile represents the user currently logged on to the computer.
Note: After this policy has been successfully applied to designated agent computers, the user profile is registered at the manager the next time a user logs in.
Default: Computer
