Previous Topic: Diagnostics and TroubleshootingNext Topic: Domains
Unable to Deploy Package from Scalability Server
Symptom:
I set up a deployment job but it failed to execute successfully. I received the following error messages:
Solution:
These system error codes map to the following Windows OS error codes:
ERROR_INVALID_PASSWORD
86
0x56
The specified network password is not correct.
ERROR_LOGON_FAILURE
1326
0x52E
Logon failure: unknown user name or bad password.
In each case you need to verify the user name and password specified for accessing the scalability server.
