Select the type, name, and description for the procedure to create. You may also specify transforms to be applied.
Delivers and performs a local installation
Performs an installation from an administrative installation
Enter the procedure name here.
Enter a procedure description here.
If the procedures will be based on one or more transforms, add the transforms in a semicolon separated list. You may also browse for transforms.
If you select the Advanced button, another browse button will display to the right. Using this browse button you can select an MSI .ini-file that the procedure will be based on. A window opens in which you can browse for the .ini-file you want to use.
The Advanced button toggles the second browse button on and off.
The MSI .ini-file can contain the sections [MSI], [MST], [Options], and [Display]. The wizard will load the data from the file and set the properties/options based on the data.
