The wizard has determined that the MSI file you are about to register, is a package created by Install Shield as a "standard MSI type".
To successfully execute this package, both an executable (that will drive the setup) and a response file (that enables unattended installations) are required.
Name and location of the executable file
Name and location of the response file.
