To register a MSI Procedure you first have to select on of the following methods:
Then follow the wizard for the next steps:
Note: For a better understanding of MSI Procedure registration, read the Registering MSI Packages in the Software Library section in the Software Delivery Administration Guide.
Note: If you want computers to do network installs of MSI packages on Software Delivery agents, you should make an administrative install on the Software Delivery manager that is nearest upstream from the Software Delivery agent, that is, on a Domain Manager or Scalability Server.
