Previous Topic: Video Capture Policy GroupNext Topic: Manager Policy Group (Remote Control)
Notes on Secure Control in Polling capture mode on Windows
Missing Application Windows
Some semi-transparent application windows, such as the Windows Vista Sidebar and the Microsoft Office Assistant, will not be visible in a Secure Control session when using Polling capture mode. However, the vast majority of applications will appear as normal.
Information Leakage
When Polling capture is enabled during a Secure Control session, the user of the host is presented with a "Remote Control Session In Progress" message, which obscures the view of the desktop. However, some elements of the screen may still present themselves to the user in certain circumstances:
If you are concerned about this possible information leakage in Secure Control mode, we recommend you select the Driver video capture mode, as the default Auto video capture mode will fall back to Polling mode if the video driver is unavailable.
More information:
General Policy Group (Host)
