You can enable or disable the replication of software inventory discovered by heuristic scanning to include or exclude them from replication.
To configure the replication of heuristic detected software
The Replicate Heuristic to Enterprise... context menu appears. A check mark before the option indicates that the replication is already enabled.
Note: Enabling replication of heuristic software for one computer applies to all the computers having heuristic data.
Note: Disabling replication of heuristic software for one computer applies to all the computers having heuristic data.
Note: When you disable the replication of the heuristic detected software, the heuristic detected software for all the computers will be deleted from the Enterprise. However, the heuristic software definitions created on the Enterprise will not be deleted.
