The All Engine Tasks pane displays all the engines tasks in the domain. It also lists the following predefined engine tasks for which you can view and modify scheduling and other options:
Executes the directory synchronization job configured under Control Panel, Directory Integration, Directory Synchronization folder. This job is scheduled to run once a day. You can modify this by right-clicking and selecting Scheduling.
Downloads new software signatures from CA Online Content Service to the domain database.
Note: The default software contents download job runs once each day between 12 a.m. and 6 a.m.
Important! Do not run CAF Stop while the software signatures are being downloaded. The download process updates many important tables in the database which needs to be consistent. So, if you kill the process, data can become inconsistent. The download process is a java executable, so check for java.exe in the process list and check that the job ‘Default Software Contents Download Job’ is not running by navigating to the System Engine in the Control Panel. By default, this job is scheduled to run once a day. You can right-click the job and select Scheduling to change the scheduling for the job.
Processes SCAP checklists located in the ITCM_installpath\SCAP_Checklists folder. If there are new or updated checklists, this job creates a compressed archive of the checklist files, and creates or updates inventory detection modules for the new or updated checklists. By default, this job runs once a day; you can, however, force the engine to run this job when you have added or modified the checklists by clicking the
button in the Engine Task List.
Executes the default engine collect task configured under Control Panel, Engines, Engine Tasks, Collect Tasks folder.
Note: Do not link the default engine tasks to any other engine.
Tasks Section
Opens the New Job wizard that lets you create an engine job.
