You can enable or disable the replication of additional inventory components to include or exclude them from replication.
To configure the replication of additional inventory components
The status of the Replicate to Enterprise⦠context menu of the component indicates whether the replication of the component is enabled or disabled.
Note: Enabling a component for replication for one computer applies to all the computers having data available for that component.
Note: Disabling a component for replication for one computer applies to all the computers having data available for that component.
Note: When you remove a component from the replication schema, the replicated inventory data will be deleted from the Enterprise.
