Previous Topic: Access the Replay Export ToolNext Topic: gui_rcLaunch Command—Launch Replayer
Export Options Dialog
The Export Options dialog lets you convert proprietary *.urc files to AVI or Windows Media (WMV) format.
Note: Unless you are familiar with conversion formats and video compression codecs, accept the default configuration options. For more information about changing the settings, See sthe Remote Control Administration Guide.
