Previous Topic: Export Options DialogNext Topic: Glossary
gui_rcLaunch Command—Launch Replayer
The gui_rcLaunch.exe program can launch the Remote Control replayer. The requisite command prompt parameter is REPLAY.
gui_rcLaunch.exe [{VIEW | REPLAY} [Options]]
REPLAY
Specifies the Remote Control replayer component.
/R filename
Specifies the file name and path for the recording of a session.
Note: There can be zero or more spaces between the /R option and the filename parameter. If the parameter contains spaces, it must be surrounded by quotes.
Example: Replay Recorded Session test.urc
gui_rcLaunch REPLAY /R "C:\test.urc"
Note: For more information about of all of the command prompt parameters for gui_rcLaunch.exe, see the Remote Control Viewer Help.
