The wizards guide you through the process of creating and registering boot and OS images.
During the process and when the process has finished, additional buttons are available to control the wizards' progress.
Use this button to abort an already started process. Depending on the process phase abortion can be difficult. Click the button again after a few seconds until a message box is displayed asking for the abortion.
The button will be enabled if you have to insert a further CD when creating an OS image for Linux operating systems.
If you want to start the creation or registration process again, escpecially in case of errors, click the Run Wizard button. You will be guided through the wizard steps and you can correct your previous settings before starting the process again.
Clicking the OK button will leave the wizard and return to previously selected node in the DSM Explorer.
