Image Prepare System › Wizards Folder › Update Boot Image Wizard
The Update Boot Image wizard guides you through the process of updating a boot image. The wizard contains all necessary information to complete the task. If you need more details, see the OS Installation Administration Guide.
The basic steps to update a boot image are as follows:
- Select the boot image you want to update.
- Specify whether you want to update only the local image, or only register the image in the domain, or do both. Depending on your selection, the wizard takes you to different set of pages.
- If you have opted to update the local image, you must provide the path to store the updated image and the path to additional files such as Windows AIK installation directory, Windows PE Boot Loader file, device drivers, and so on.
- If you have opted to register the image in the domain, you must select a registration option and then provide the domain authentication details.
- Review the settings and click Finish to start the image update.
