The OS Images folder displays a list of OS images registered in the domain or detected by a boot server.
OS images not yet registered appear as "detected" images.
OS images are also available as software packages in the Software Package Library.
For each OS image the following information will be displayed:
Specifies the name of the image.
Specifies the type of the image with the "short name" of the operating system,for example, WXPP, W2008.
If the image is not yet registered, it is shown as "detected".
Specifies the "long name" of the operating system, for example, Windows XP Professional.
Lists the image flags defined for the image. For more information about Image Flags, see the OS Installation Management Administration Guide.
Note: This field is empty for images that are created with the earlier version of Client Automation.
Specifies the date and time of registration of the image; subsequently, if the image is modified, this field is updated to include the date and time when the image is modified.
Specifies the name of the codepage, for example, "1252 - Western European"
Specifies the comment that appears in the software delivery product.
Default: BsmOsImg imagename
Specifies the name of SD package.
