In addition to using the default policy, you can create new policies based on your specific requirements.
To create a new configuration policy
The New Configuration Policy dialog opens.
Note: The New Configuration Policy dialog is identical to the Configuration Policy Properties dialog, except the Name and Description fields are enabled, so that you can create a new configuration policy.
The new policy is listed in the tree view and in the Configuration Policy pane.
Note: The default values for a newly created policy are inherited from the default policy.
