Previous Topic: Detected ImagesNext Topic: Boot Images Folder
Images Flagged as Not FIPS-Compliant
When Client Automation is operating in FIPS-only mode, boot and OS images created with the earlier versions of Client Automation show the image type as Not FIPS-Compliant in DSM Explorer, as these images are not FIPS-compliant. These images have a "X" icon to indicate that the images can no longer be used. You cannot use these images to set up OS installations and you cannot edit the image parameters or the OS installation parameters for these images. You must update such images to FIPS-compliant format to use them in FIPS-only mode. For more information about updating OS and boot images, see the OS Installation Management Administration Guide.
