Previous Topic: Boot / OS Image Properties TabNext Topic: Boot Servers
Image Flags Tab
This tab displays the image flags defined for the registered boot or OS image. If you want to modify the image flags assigned to an image, open the osinfo.ini file of the image and update the imageflags parameter. Images created with the earlier version of Client Automation do not support image flags until you update the images. For more information about updating the images and the imageflags parameter, see the OS Installation Management Administration Guide.
