The Add Argument dialog displays the inventory and template information that you can query.
Specifies an operator for the argument. In addition to the relational operators, you can select the following operators. These operators compare the previous value of the selected inventory and its current value.
Returns true if the value has increased from the previous scan by the specified number.
Returns true if the value has decreased from the previous scan by the specified number.
Returns true if the value has changed from the previous scan.
Returns true if the value has doubled since the previous scan.
