The Add Argument—File Contents dialog for file contents lets you select the configuration file or file group you want to query.
This dialog has the following fields:
Displays the configuration file groups and files in the domain. Click the file group to view the configuration files under it. You can search all the files under a group or search a particular file for the given value.
Displays the Like operator that you can use for performing wildcard search.
Defines the text you want to search in the configuration file or file group. As the entire configuration file is searched for the given value, the value needs to have a wildcard character. Specifying a value without a wildcard character returns true only if the entire file contents match the given value.
For example, if you are searching for the word Timeout in the config.sys file, you need to give the value as Timeout*.
