Triggers the SNMP Trap. In this case, the Engine component validates the policy and traps are forwarded to Event management.
Thus, trap-directed notification can result in substantial savings of network and agent resources.
The Configure Policy Actions dialog for this policy contains the following fields and check box:
Specifies the IP Address.
Uses the IP Address given in the preceding field as default.
Defines the text you want to view in the policy notification.
Specifies the macro that you want to add to the notification message. You can add any number of macros to the message.
Adds the selected macro to the message.
Evaluates the policy as defined during policy creation.
When you select this check box, the following happens when an asset no longer complies with the policy:
