You can log the policy notification in the Unicenter Event Console. You can access the event console from Tools, Unicenter, Event Console menu in the DSM Explorer.
Note: The Engine generates the log entry on the computer on which it is installed.
The Configure Policy Actions dialog for this policy contains the following fields and check box:
Defines the text to be logged in the Unicenter Event Log.
Specifies the macro that you want to add to the notification message. You can add any number of macros to the message.
Adds the selected macro to the message.
Evaluates the policy as defined during policy creation.
When you select this check box, the following happens when an asset no longer complies with the policy:
