You can specify the Intel AMT remote commands that you want to execute on the Intel AMT assets when the policy is violated. These commands let you control the Intel AMT assets.
The Configure Policy Actions dialog for this policy contains the following drop-down and check box:
Lists all the commands and lets you select the command that you want to run on the Intel AMT asset. The available commands are as follows:
Shuts down the Intel AMT asset.
Starts the Intel AMT asset.
Puts the Intel AMT asset in quarantine.
Releases the Intel AMT asset from the port - reverse of quarantine.
Evaluates the policy as defined during policy creation.
When you select this check box, the following happens when an asset no longer complies with the policy:
