Use this tab to either enter SQL commands or load a SQL script you want to execute.
This tab contains the following fields:
Defines the SQL command or displays the contents of the loaded SQL script file.
Opens the Load file to the Job Editor dialog. Locate the SQL script file and click Open. The contents of this file appear in the text area. If you modify the SQL script file, you need to load it again to execute and display the modified commands.
