External utility tasks are used to run an external application on the system engine. You can specify various run options, and optionally create a text file to pass to the executable file using parameter options.
This folder lists all external utility tasks defined in this domain.
To view and modify the external utility tasks, click Properties in the Tasks section of the information pane.
