Previous Topic: Establishing Connections on Different PortsNext Topic: File Transfer Feature
End a Remote Control Session
There are multiple ways to end a remote control session.
  1. Click the My Sessions tree node.
  2. Right-click the computer from which you want to disconnect, click Disconnect, and select one of the disconnect options from the context menu.
  3. Alternatively, click the Down Arrow button to the right of the Disconnect toolbar button, and then select one of the disconnect options.
  4. Click Yes.
    The remote control session is ended according to the disconnect option selected.
    Note: For the Disconnect and Log Off and Disconnect and Reboot options, a countdown dialog appears after clicking Yes in the Logoff/Reboot confirmation dialog. The timer is set to 30 seconds by default. Once the countdown stops, the logoff or reboot is initiated and the session is actually disconnected when the logoff or reboot, is complete.
