The File Transfer option lets you copy and paste single and multiple files or groups of files from different locations on the local computer.
Note: If you try to transfer a folder from the viewer to a host, the transfer fails with the error No such file or directory. This problem does not affect single and multiple file copies, it affects only the transfer of the directory trees.
Note: For more information about enabling the File Transfer feature, see the Remote Control Host Help for information.
