Use the Viewer tab to set the viewer’s remote control session behavior at the start of the connection. The options set here can be modified during the session using the toolbar or the Active Sessions context menu options.
Note: Changes made on this tab only apply during the current session and are lost if the session is removed.
Note: The default setting is False.
Click Browse to invoke the File Save dialog, letting you specify a recording file name.
Default: A default name is automatically generated, based on the default recording path, computer name, and current date and time.
Remote Control attempts to connect you to the host computer after all fields in the dialog are completed.
Note: The Help button is not available when you use the RC Viewer Web Interface.
