Use the Experience tab to control the connection speed and set visual effects.
Default: Fast LAN (100 Mbit)
Note: If you manually change any of the other options in the Experience tab, the Connection Speed option changes to Custom.
Note: Dithering is only available in High Color: 16 bits/pixel, Low Color: 8 bits/pixel, Greyscale: 4 bits/pixel, and Greyscale: 1 bit/pixel reduction.
Your visual effects settings are saved.
Note: The Help button is not available when you use the RC Viewer Web Interface.
