Previous Topic: Connection Addresses DialogNext Topic: Specify Connection Settings
Connection Settings Dialog
Use the Connection Settings dialog to configure the connection to a remote computer. From this dialog you can view, modify, and select a connection type, address, and user name. This dialog contains the following tabs with settings that may be configured before connecting to a computer:
In the DSM Explorer you can access this dialog by selecting the Remote Control node under an asset.
In the Remote Control viewer, you can access this dialog by double-clicking a computer or right-clicking a computer and clicking Open from any of the following locations:
Note: You can also access the Connection Settings dialog by clicking Connect in the Tasks portlet in the right pane or by clicking Quick Connect in the Remote Control Tools menu.
More information:
Set the Maximum Bandwidth
Configure Recording Options
gui_rcLaunch Command—Launch Viewer
Quick Connect Sessions
