Previous Topic: Configure Viewer Display and Control OptionsNext Topic: Browse for Folder
Configure Recording Options
You can enable or disable the default connection settings for the recording of remote control sessions and to select the location to save the recording.
  1. Right-click the Viewer node and select Properties.
  2. Select Record.
  3. (Optional) Specify whether recording begins at the start of each session. By default this option is not enabled.
    Note: This behavior can be changed before establishing a session by adjusting the setting on the Viewer tab of the Connection Settings dialog.
  4. Specify the default path where you want to save the recorded sessions. If the path is left blank, the system-wide Temporary folder is used.
    Note: This path can be overridden before establishing a session by adjusting the setting on the Viewer tab of the Connection Settings dialog.
  5. (Optional) Click Browse to access the Browse for Folder dialog, which lets you navigate the folder path for saving recorded sessions.
  6. Click OK.
    Your recording options are saved.
More information:
Connection Settings Dialog
