Previous Topic: Add Action: Delete AssetNext Topic: Add Action: Unicenter Event Log
Add Action: System Event Log
You can log policy notification in the System Event Log. The notification is logged on the engine evaluating the policy.
The Configure Policy Actions dialog for this policy contains the following fields and check box:
Enter message
Defines the text to be logged in the System Event Log.
Macro
Specifies the macro that you want to add to the notification message. You can add any number of macros to the message.
Add
Adds the selected macro to the message.
Perform action when Asset no longer violates Policy
Evaluates the policy as defined during policy creation.
When you select this check box, the following happens when an asset no longer complies with the policy:
