The Text File tab lets you enter the text file content.
This tab has the following field and a button:
Defines the text file content that you want to send as a parameter to the executable. You can either type the content or load the contents of a file. This field is enabled only if you have selected Create text file field in the Utility tab.
Lets you browse for the text file and load the contents.
