External utility jobs are used to run an application on an agent computer. You can specify various run options and optionally create a text file to pass to the executable file using parameter options.
This folder lists all external utility jobs defined in this domain.
To deploy any of these jobs, select the job and drag-and-drop it to the appropriate asset or group.
Note: Ensure that the application exists on the agent computer.
