Secure Configuration File jobs are used to ensure that specified backup files are always equal to the content (secure file) specified here. If the specified backup file is changed, it will be restored to the original content.
Whenever a computer starts on the network, the configuration file (for example, CONFIG.SYS) on the local agent is compared with the secure file. If there is a difference between the two files, the secure file is copied to the computer and the existing file is overwritten.
This folder lists all secure configuration file jobs defined in this domain.
To deploy any of these jobs, select it and drag and drop it to the appropriate asset or group.
To create a new secure configuration file job, click New in the Tasks section to open the New Job Wizard. This wizard guides you through the creation of the new job.
