Previous Topic: Organize Category DialogNext Topic: Create New Product Dialog - General Tab
Organize Product Dialog
The Organize Product dialog lets you add the following:
This dialog contains the following fields:
Title
Defines the name of the software definition to be searched.
Version Label
Defines the version of the software definition to be searched.
Manufacturer
Specifies the manufacturer for the software definition.
Type
Specifies the software definition type to be searched.
Category
Specifies whether the definitions must be a member or non-member of the selected category.
Show only Discovered Software
Filters only those software definitions that are discovered by the asset management agent.
Search
Searches the selected software definition type for the given values.
Search Result
Displays the title and version label of the resulting software definitions. You can select the items you want to add to the product, release, or suite.
Note: To select multiple items all at once, press the Shift key (continuous selection) or Ctrl key (random selection) and click the items.
Add
Adds the selected items to the Selected Definitions section.
Note: Clicking this button does not add the items to the product, release, or suite.
Add All
Adds all the items in the Search Results section to the Selected Definitions section.
Displays the title and version label of all the added definitions. These definitions are added to the category when you click OK.
Remove
Removes the selected items from the Selected Definitions section.
Remove All
Removes all the items from the Selected Definitions section.
