Previous Topic: Categories FolderNext Topic: Organize Product Dialog
Organize Category Dialog
The Organize Category dialog lets you add software definitions to a category. You can search the software definition types such as product, release, patch, suite, and suite component and add it to the category. Use wildcards for searching the title and version label.
This dialog contains the following fields:
Title
Defines the name of the software definition to be searched.
Version Label
Defines the version of the software definition to be searched.
Manufacturer
Specifies the name of the manufacturer. For example, to organize all the products from a manufacturer in one category, select only the manufacturer name in this field and leave the title and version label blank.
Type
Specifies the software definition type to be searched. For example, to organize all the suite components in the domain in one category, select Suite Component in this field and Manufacturer as <All>.
Category
Specifies whether the definitions must be a member or non-member of the selected category.
Show only Discovered Software
Filters only those software definitions that are discovered by the asset management agent.
Search
Searches the selected software definition type for the given values.
Search Result
Displays the title and version label of the resulting software definitions. You can select the items you want to add to the category.
Note: To select multiple items all at once, press the Shift key (continuous selection) or Ctrl key (random selection) and click the items.
Add
Adds the selected items to the Selected Definitions section.
Note: Clicking this button does not add the items to the category.
Add All
Adds all the items in the Search Results section to the Selected Definitions section.
Displays the title and version label of all the added definitions. These definitions will be added to the category when you click the OK button in this dialog.
Remove
Removes the selected items from the Selected Definitions section.
Remove All
Removes all the items from the Selected Definitions section.
