Previous Topic: Organize Product DialogNext Topic: Create New Release/Suite/Patch Dialog: General Tab
Create New Product Dialog - General Tab
Use the General tab to specify the general information about the definitions such as the name and version.
This tab contains the following fields:
Name
Defines a unique name for the definition
Version
Defines the version of the definition.
Example: V1.0.
Query Version
Defines the query version of the definition.
Example: 1.0.0.0
Manufacturer
Specifies the manufacturer of the definition. If the manufacturer you are looking for is not in the list, you can create a manufacturer in the Manufacturer folder.
Description
Describes the product.
